Topic: BNC WC Sync Question
Hi there
I have just slaved a Presonus DigimaxFS to my MultifaceII and am not sure if the WC is operating properly and wish to check this with you good people. I'm using the DigimaxFS purely for 8 additional channels via ADAT.
My MultifaceII settings are:
I have a 75 Ohm BNC cable from WC Out of my MutifaceII going to the WC In of my DigimaxFS...I have also pressed in the 75 Ohm termination switch on the Digimax. I also have my optical cable from the ADAT Out of my DigimaxFS to the ADAT In on my MultifaceII.
The WC lock LED on the front of my Mutliface is not lit but the ADAT is. Should this WC lock LED be lit? Or are these lock LEDs only for incoming signals?
Basically are my settings above correct? If not, I would greatly appreciate some advice to correct it.
Incidentally my DigimaxFS appears to be successfully synced externally via BNC at 44.1k.
LiD
