Topic: Hammerfall Multiface I and Ubuntustudio
Hi Folks,
try to get Jack working with my Soundcard Hammerfall Multiface I on Ubuntustudio 9.10
Card is recognized, hdspmixer is working fine. When trying to connect Jack I get following Error message:
0:28:20.070 Startup script...
00:28:20.073 artsshell -q terminate
sh: artsshell: not found
00:28:20.475 Startup script terminated mit R?ckgabewert = 32512.
00:28:20.475 JACK startet...
00:28:20.475 /usr/bin/jackd -R -P2 -dalsa -r44100 -p256 -n3 -D -Chw:0,0 -Phw:0,0 -i2 -o2 -I1 -O1
00:28:20.482 JACK wurde mit PID = 3846 gestartet.
no message buffer overruns
jackd 0.116.1
Copyright 2001-2005 Paul Davis and others.
jackd comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK compiled with System V SHM support.
cannot lock down memory for jackd (Cannot allocate memory)
loading driver ..
apparent rate = 44100
creating alsa driver ... hw:0,0|hw:0,0|256|3|44100|2|2|nomon|swmeter|-|32bit
control device hw:0
configuring for 44100Hz, period = 256 frames (5.8 ms), buffer = 3 periods
ALSA: final selected sample format for capture: 32bit integer little-endian
ALSA: cannot set channel count to 2 for capture
ALSA: cannot configure capture channel
cannot load driver module alsa
00:28:20.513 JACK wurde angehalten erfolgreich.
00:28:20.513 Post-shutdown script...
00:28:20.514 killall jackd
jackd: no process found
00:28:20.922 Post-shutdown script terminated mit R?ckgabewert = 256.
00:28:22.550 Keine Verbindungsaufnahme als Client zum JACK-Server m?glich. - Overall operation failed. - Verbindungsaufnahme zum Server gescheitert. Bitte sehen Sie im Meldungsfenster nach weiteren Informationen.
Any Ideas? Thanks a lot!
Cheers, Pepe.
Re: Hammerfall Multiface I and Ubuntustudio
Solved, Card is working fine now. Don't know exactly what I did, messed around with settings in Jack, switched to 48000 (perhaps that was the reason), gave more Memory for Audio, etc.
Still have some xruns from time to time, but most the time it's stable.
Pepe.
You probably changed the capture channel to 18 for anyone who's still struggling.
Now I'm wondering how you got the RME to play nice with Ubuntu Studio 9.10. Jack and others see it but I have the host error light on. Any ideas?
~Brian
This worked!!
http://kijjaz.exteen.com/20091117/rme-h … buntu-9-10
::joy::
Time to record!
Now if I can only sync both my soundcards, I'll be in linux audio heaven.
~Brian
