Topic: HDSP 9632 Midi Problems
I?ve bought a second hand 9632. Everything works fine except the midi functions. It seems no signal is sent to or from my computer, I have all In/OUT ports activated but I don?t get midi signal. I installed the latest firmware and driver but this makes no difference. When I connect my keyboard to a separate midi interface I do get midi signal so I think there?s something wrong with the card. The drivers are installed correctly and in the device manager it says everything works properly. When I check the 9632 properties I see Audio devices, Midi Devices and instruments and mixer devices. I checked ?use midi features on this device? as well.
Could there be a hardware related problem and is there a way to check this? Maybe the breakout cable is faulty but it?s remarkable that both Midi In and Out don?t seem to work.
Any idea to sort this out?
Thanks and all the best,
Seppe De Vos
