Topic: Fireface UC does not find host MBP
the Fireface UC I just ordered does not work with my MBP. I switched cables, re-installed the drivers etc etc. Nothing helps. The Fireface USB Mixer and Fireface USB Settings are not starting automatically when I connect the Fireface UC to my MBP, and when I start them manually they close themselves.
I hooked the Fireface UC up to a windows 7 machine, this works perfect.
Any idea what the problem might be, how to get it solved?
Best Lucas
Re: Fireface UC does not find host MBP
Sounds like you forgot to change to Apple firmware, as explained in the manual (hint: double click the knob when the unit is on, but not connected via USB).
Aha thank you!
Did not know about this. Since the Fireface and Multiface always worked out of the box I never used the manual.....
Best Lucas
The UC's package contains an extra paper which clearly and only talks about this setup issue. No need to search in the manual.
