Topic: Wavelab 6 Digi96/8 scroll problem
I just recently upgraded to Wavelab 6, with a new PC, using the Digi96/8. My problem is the cursor scroll in both the wave and audio montage window, lags behind when playback is initiated. It takes any where from 6 to 10 seconds to finally catch up, and from there stays pretty in sync with the audio. This happens no matter which driver I use, either WDM or ASIO, and from what I can find on the RME website, I have the most recent driver, vers.2.11. If anyone has any suggestions, I would greatly appreciate any help. This has been very frustrating as Steinberg could not offer any solution, and a couple of emails to RME have not been answered.
Thank You!
WaveLab 6.10 (build 340) - English
Windows XP (Minor version: 1) Build Nr: 2600 - Service Pack 3
Intel(R)Core(TM)2 Duo CPU
E7500 @ 2.93 GHZ
Total Physical memory: 3036 MB
Intel(R) G45/G43 Express Chipset
    Primary display
    Current Settings 1920 x 1080 (colors: 32 bits)
= Audio Input Devices =
-1 -> Microsoft Sound Mapper (version 1280)
0 -> DIGI96/8 In (1+2)(1) (version 850)
1 -> DIGI96/8 In (3+4)(1) (version 850)
2 -> DIGI96/8 In (5+6)(1) (version 850)
3 -> DIGI96/8 In (7+8)(1) (version 850)
= Audio Output Devices =
0 -> DIGI96/8 Out (1+2)(1) (version 850)
1 -> DIGI96/8 Out (3+4)(1) (version 850)
2 -> DIGI96/8 Out (5+6)(1) (version 850)
3 -> DIGI96/8 Out (7+8)(1) (version 850)
Re: Wavelab 6 Digi96/8 scroll problem
try with the latest WL 6.1.1, check Steinbergs ftp server
check under "Options" menu - Scrolling during playback
change and see if this would change behavior
other than this go to the WaveLab forum and ask
http://forum.cubase.net/phpbb2/viewforu … 766847c586
regards S-EH
Thanks for your reply and help. It turned out to be another audio driver that was installing each time I rebooted the system.
Thanks,
RMB
