Topic: FF400 as Standalone with FF800
Trying to get my FF400 to work as a standalone converter with my FF800.
Plugged the 400 to the 800 via ADAT (2 cables) and Wordclock with termination on the FF400.
Plugged it to the computer to change the settings (auto sync to ADAT) with the 800 as master - word clock - stored them.
Went to the 400's Matrix mixer view to Assign IN 1 to A1 1, IN 2 to A1 2 etc, and IN 11 to AN 1, In 12 to AN 2 and so forth.
Then Flash current mixer stage. Turned everything off, unplugged the firewire cable between the FF800 and FF400. Turned everything
back on. Basically this video, but with a FF400 http://www.youtube.com/watch?v=Oibj81QIq4s
The ADAT outputs from the FF800 work fine with the FF400. However, I can't get the inputs from the FF400 to the FF800. It works only if I plug a firewire cable between the two, then Totalmix sets 2 Units. Works ok, but could be complicated and I know it's not legit...
What I am doing wrong? Running this on a mac os x.5.8
Thank you,
Eric
