Topic: Routing/Mixing Question
Hello Folks...
I am having a hard time wrapping my head around a routing issue and need help. I will try and explain as best I can.
I have a FW800 connected to my main DAW running Vista x64. The FW800 works great; never had any problems. I have the latest Cubase 5 x64 up and running fine.
I realize the FW800 is very powerful and I use only a tiny portion of its potential. Mostly I just use AN1/2 to monitor the output from Cubase. I loop AN1/2 back into Cubase to record the output directly when necessary.
Here is what I am trying to do:
Since I cannot get Gigaplayer to work at all I have installed G-Player which is a giga sample player. It can work as a plug-in or as stand-alone. I use it in stand-alone mode as this is the only way I can seem to get the VSL performance tool to work in conjunction with G-Player. Routing MIDI from Cubase into the Performance Tool then into G-Player works perfectly. Since I have both Cubase and G-Player accessing the FW800 at the same time the outputs must be unique in order to support multi-client operation. I set the outputs of G-Player to AN3/4 and I can play back MIDI channels in Cubase and both Cubase and G-Player will sound simultaneously on different audio channels that can be heard through AN1/2.
What I would like is to be able to route the audio from G-Player back into Cubase so I can process the signal. However, I cannot create a bus in Cubase using the same outputs as G-Player or multi-client operation fails. So...how do I get the AN3/4 into Cubase so I can monitor and process the signal? Is this even possible?
I tried creating an input bus in Cubase using AN7/8. So I have G-Player out on AN3/4 trying to go into AN7/8 so I can hear the playback on AN1/2 from Cubase. I have confused myself so badly that I need help trying to figure this out. I cannot seem to figure this out, and any assitance would be greatly appreciated. I have tried messing with the matrix for hours and I am lost. The only way I can hear anything is if the signal is also sent to AN 1/2 along with any other routing.
Basically, I need Output of AN3/4 to be routed to Input of 7/8 so I can monitor the signal in Cubase on AN1/2. I am not restricted to the AN channels by the way, just listing them for conveinance.
Also, does anyone know if there is a way I could route Cubase MIDI to the G-Player plug-in thereby just keeping everything inside Cubase?
I love composing, but the technical stuff stumps me from time to time and I really need help!
Thank you.
Todd Masten
www.toddmasten.com
