Topic: Use MBox spdif as extra 2 pre's with fireface???
I have fface 800 and an mbox2, I run logic 9 with the fface.
i am needing some more pre's to add for guides when tracking.  i have an old mbox 2.
Is it possible to link the mbox 2 via spdif to the fface and use the mbox pre's as spdif inputs?
I think not as there is no way to sync the two units?  Mbox 2 has no word clock or adat etc.
Any help appreciated.
thanks
Re: Use MBox spdif as extra 2 pre's with fireface???
If you can't clock the mbox externally, it will have to operate as master (FF on Autosync). Otherwise it should work...
Thanks for reply.
I would then have the mbox as master and the fface 800 as slave?  Which wouldn't be good.
Not really something to worry about, especially since the FF has got Steadyclock...
