1 (edited by georgeludwig 2010-04-30 06:04:44)
Topic: lighpipe output only outputs16 bit resolution...by design?
I'm using the optical output in SPDIF mode on my FF400 to send a digital signal to a field recorder (Sony PCM-D50). It works great, except the D-50 only detects a 16 bit signal. The D-50 is a 24 bit recorder, and it auto detects the bit-depth.
Does the lightpipe output just not suppport 24 bits due to the format, or have I screwed something up somewhere?
I'm uising the latest driver and ROM. I've experienced the issue under both Windows as well as OSX.
I'd appreciate any help...it's a drag to only get 16 bit.
-George
Re: lighpipe output only outputs16 bit resolution...by design?
This previous forum thread may help:
http://www.rme-audio.de/forum/viewtopic.php?id=6243
Thanks for the pointer! I did a search before posting, but I guess my keywords weren't good enough. sad
