1 (edited by Stevie 2018-01-15 19:12:32)
Topic: TotalKeyMix 1.0 released - Windows volume control for TotalMix
I proudly present the release of TotalKeyMix! It's a tool to control the main volume of TotalMix with hotkeys (Windows only).
You can find the download and installation instructions here:
http://www.stephanroemer.net/stuff/tota … eymix.html
EDIT: I redesigned my website and since I hadn't seen much interest in TotalKeyMix (and also because I'm not using it anymore), I have removed it. However, I provided the original source code to Ikonomov and he recompiled it with an older AHK version and posted it here: https://autohotkey.com/boards/viewtopic … mp;t=42686
So, feel free to grab it there and even modify it to your needs!
Re: TotalKeyMix 1.0 released - Windows volume control for TotalMix
Wow, thanks for the sticky! smile
There will soon be an update that fixes the "full volume" issue on Windows startup.
Thanks a lot, Stevie!
Really useful stuff.
Now I can use TotalKeyMix on my older card the same way like having a Remote Control:
"Features Fireface UFX
The Remote Control is the perfect partner for the Fireface UFX. The unit allows to control the most important monitoring functions:
- Volume control of the main output and both headphone outputs (switchable)
- DIM (user adjustable value)
- Recall and store of a reference level for the main outputs (user adjustable value)
- Left button (Prog) is programmable and can control functions like Talkback, Speaker B, mono etc.
What I still miss is a reference level switch. Hope you can extend your work on that feature sometime.
Anyway, great job!
Can't wait for the bugfix.
Hi, thanks for the program. I'd like to request a new feature, make the talkback button assignable to a keyboard shortcut as well. I really need that and I don't want to buy a midi controller for that one function...
If this is already possible somehow with autohotkey and MIDI Yoke, a step by step guide would be greatly appreciated, and can't seem to make heads or tails of it! :roll
Hey guys!
As usual, time is too short to work more on TKM :roll but I will keep that in mind for future releases.
Cheers,
Stevie
Is there an an alternate for midi yoke ?  I'm using windows 7 64 bit. and it won't install:(
You could actually use http://nerds.de/en/loopbe1.html or http://www.tobias-erichsen.de/loopMIDI.html
Thank you very much Stevie smile
You're welcome smile
This application is wonderfull! I like it! I've a question: How I can choose the totalmix channel ? I can control only the first pair of channel. (1-2). In can control channel number 3 , or 4 or 5 etc.. ?
Yes, that's right, you can only control the main out.
sad
Thank you Steve!
Sorry, if my time would permit, I would include more features hmm
I'm working on a project where I'm intended to play and record at specific times automatically. I haven't still decided if the babyface or a HDSP card is the best option. In any case I need to use a Windows Pc and command the card remotely. I wonder if you have any SDK, libraries or any tool wich would make this posible for a developer.
David Hernandez
Hi!
This looks realy usefull. However, I can't get it to work on the Main control room out (or any hardware output either). The only fader in Total Mix I'm controling is the hardware input faders.
I tried to change this line in the xml-file:
<Keys>
                <F7 Modifiers="Shift,Control">NoteOff, 1, 53,0</F7>
</Keys>
Accoring to the UFX manual a cc volume change should do the trick. But I cant figure out how. Can any one lead me on the way?
/Johan
Is there any alternative solutions for OSX 10.8+ ?
Rme Ucx + Arc
Unfortunately this link is dead now sad
Loyal RME user since 2001
[AMD 5800X, 32Gb RAM, Win10x64, NVidia GTX1080ti, UCX+UFX, REAPER x64]
Can anyone host this or does anyone know of a working mirror? I have tried every link I could come by through google to no avail.
Hi, I have a copy of TotalKeyMix 1.0
But I don´t know if it´s okay to share ...
BR Thomas
Multiface, Digiface, Raydat
If you will, you can send it through email. I can PM my email address.
YEP!
23 (edited by ikonomov 2018-01-12 06:32:27)
Edit: Please see post #25 below for an updated download link.
The download link by Stevie in the first post is dead.  It was archived by the Wayback Machine however.
web.archive.org/web/20161102235028/stephanroemer.net/stuff/totalkeymix/totalkeymix.html, including a download link of 1.0.2b version which according to the readme fixes the problem with the stored volume level at start up
web.archive.org/web/20160508042407/stephanroemer.net/resources/download/TotalKeyMix_v1.0.2b.zip.  Here is a post by Stevie with the script autohotkey.com/board/topic/17212-midi-output-from-ahk/?p=292047.
24 (edited by Stevie 2018-01-11 23:17:31)
Hey guys, sorry for not writing here for a while. I re-did my website and I thought there was not much interesst in TotalKeyMix (with all the iPad tools like Lemur and TouchOSC out there), that's why I didn't put it on my website anymore.
I'm completely okay with it, if you modify/share the script!
25 (edited by ikonomov 2018-01-17 02:21:30)
Stephan was kind enough to respond to my email and provide the source code and give the permission to re-post his files.  I uploaded a .zip file at the AutoHotKey forums with the source code, compiled .exe, his original instructions and a short updated readme to get things working on newer versions of Windows.
https://autohotkey.com/boards/viewtopic … mp;t=42686 (EDIT: This is the same link in the now updated first post of this thread)
26
Thanks! This will sure help some users!
27 (edited by ikonomov 2018-01-12 05:24:10)
I find it indispensable and wish I've found it years ago.  It allows me to control the volume of my monitors with an MCE remote controller.  It should also work with most standard remote controllers for windows.  It makes all the sense in the world to separate the windows volume from TotalMix, but ever since I bought my Babyface I've always wished to have another way to control the volume (without a MIDI controller).  Huge thanks to Stephan.
In this related post https://autohotkey.com/board/topic/1721 … ntry292047
I see an information "You need to have MIDI Yoke installed"
What is MIDI Yoke ?
29 (edited by ikonomov 2018-01-12 09:09:22)
What is MIDI Yoke ?
Hi ramses, I assume you have visited the old links I provided in my first post.  I posted an updated download link with instructions how to get things working at post #25 above (https://autohotkey.com/boards/viewtopic … mp;t=42686)  Download the .zip file there, unzip it and read readme.pdf and then readme_2018.pdf.  It was fairly simple and straight forward to get things working here.  Give a shout if you need some additional help afterwards.
I updated the original post with the info, thanks ikonomov for doing this!
Thank you Stevie for updating your original post with the new link.  I just uploaded a new version that allows easy customization of the speed of the Volume Up/Down buttons through the config.ini file.
Version 1.0.5 released with Volume On-Screen-Display!
Hello friends!
I have been interested in TotalKeyMix for about 4 years. Thank you all for collaborating for this great cause!
I found version 1.05 yesterday that includes some improvements and I love it. I keep this thread in favorites smile
Thank you!
Hey, I'll take a small credit for the improvements and thank you for the compliments.
I have updated the readme inside the download file found on the AutoHotkey forum with a workaround for a problem I found that prevents system standby.  The issue has been reported here https://www.forum.rme-audio.de/viewtopic.php?id=26684, hopefully in time it'll be resolved, but for the time being the workaround seems to work fine.
Excellent! Thanks a lot, Stevie! And also thanks to you ikonomov.
Great works are performed not by strength but by perseverance.
36 (edited by ikonomov 2019-02-21 02:03:27)
Recently I had to reinstall Windows, along with TotalKeyMix, and while reading the .pdf files I realized that I should rewrite the readme file with easier to follow instructions.  Additionally I made a few minor changes in the script and uploaded a new version 1.1.
Edit: I re-uploaded the v1.1 again with an edited readme.pdf.
37
Thanks!
THANKS so much for this solution!! It works perfectly together with my logitech g810 volume control. You guys are awesome!
Thanks to feedback from axibert I've just uploaded a new 1.2 version with updated startup configuration instructions in the readme.pdf file. It takes a few extra clicks, but should provide a much more robust way to launch the program at startup.
I've posted a new 1.2.1 version compiled using the newest AutoHotKey release.  It allows the setup menu to be displayed properly with higher DPI Windows scaling.  I've also edited the readme.pdf slightly making it easier to follow.
Would be useful in such a long thread to repeat the URL for download.
Esp. as the URL in post #1 does not work and there have also some other URLs for other tools been posted here meanwhile.
Is the source also available or only the compiled binary ?
BTW, is this tool related to or based on what I published here in my blog with a link to RME Forum where I found the solution ? https://www.tonstudio-forum.de/blog/ind … ndruck-DE/
42 (edited by ikonomov 2021-01-07 11:08:00)
The link is posted two times, in post #1 and post #25.  Same link again: https://www.autohotkey.com/boards/viewt … p;t=42686.  I thought posting it fewer times makes it easier to avoid confusion making people think there are different links.  The original download link in post #1 does not work, as stated in EDIT in the same post.  The sources for both compiled binaries are included.
The link you provided doesn't seem to be related to TotalKeyMix.
Thanks, sry .. I simply tried the 1st one which is in most cases the proper one (wrong expectation).
I've posted version 1.2.2 that reverts back to using 1.0.48.05 compiler as the .exe in v.1.2.1 was being detected as a virus.  Compatibility settings for the .exe in Windows 10 can be used to to disable DPI scaling if needed.
45 (edited by ikonomov 2022-08-23 02:03:51)
This project is now maintained by carlfriedrich at https://github.com/carlfriedrich/TotalKeyMix which has been updated to the new AutoHotKey utf-8 encoding with more configuration options and ability to control more than one fader.  In addition, it uses TotalMix's OSC Control which negates the need for using virtual loopback MIDI drivers and also making it much easier to setup.
For a simpler and more robust solution created in C# there is the tool developed by fgimian at https://github.com/fgimian/totalmix-volume-control (RME thread: https://forum.rme-audio.de/viewtopic.php?pid=174137) which also uses TotalMix's OSC Control.
In the mean time an even more comprehensive solution was developed, called Nix. It does offer more functions than totalmix-volume-control and at the same time is much smaller and most important, runs also my machine without any problems.
Nix is configured with a nice GUI and offers to show
up to three channels
control room functions (Dim, Mono, Mute, Talkback...)
hotkeys to change volume, toggle control room functions, open TotalMix FX
The (volume) display can be shown as a pop-up, whenever a change is made or can be permanent. Colors and size can be configured as well.
I have been using it extensively the last month and found it to be extremely helpful in my daily use of the RME interface.
You can download it from https://www.bsound.co.nz/tools-nix
Registration fee is only 5 dollars.
helpful information. Thanks
48 (edited by ramses 2025-12-22 13:10:15)
I added more functions to TotalKeyMix:
- an additional volume up/down control in higher resolution +/- ~0.1 and
- Dim, Mono, Speaker B
- and even more ..
See this posting on the RME forum
    https://forum.rme-audio.de/viewtopic.ph … 51#p242451
and this blog article
    https://www.tonstudio-forum.de/blog/ent … otkey-osc/
I contacted Stephan Römer today by mail to ask whether he can establish contact between me and the current maintainer (carlfriedrich on GitHub). Maybe he wants to take over the changes into his repository to create an “official” release and that the code stays maintained under source code control.
Updated to 1.6.4.3 and the blog post has been translated to German.
