Topic: Fireface UC headphones not linked (outputs 7/8)
Recently, my Fireface UC's headphone outs became "unlinked" when Totalmix is not running. That is, if I adjust the "PH" is adjusts the left volume, if I adjust "PH." it adjust the right volume.
It does work if Totalmix is running, but only if both the 7/8 outputs are highlighted ("PH R" and "PH L" both highlighted in yellow at the output mixer).
If I don't start Totalmix or if they become un-highlighted or I quit Totalmix, they are unlinked again.
Is there a setting I perhaps changed by accident?
The 7/8 output, in my case, should ALWAYS be linked, as the CR phones are there all the time. This was a ssource of serious annoyance in the last few sessions... any help would be very much appreciated!
regards
joedoc
