Topic: Fireface UC headphones not linked (outputs 7/8)
Recently, my Fireface UC's headphone outs became "unlinked" when Totalmix is not running. That is, if I adjust the "PH" is adjusts the left volume, if I adjust "PH." it adjust the right volume.
It does work if Totalmix is running, but only if both the 7/8 outputs are highlighted ("PH R" and "PH L" both highlighted in yellow at the output mixer).
If I don't start Totalmix or if they become un-highlighted or I quit Totalmix, they are unlinked again.
Is there a setting I perhaps changed by accident?
The 7/8 output, in my case, should ALWAYS be linked, as the CR phones are there all the time. This was a ssource of serious annoyance in the last few sessions... any help would be very much appreciated!
regards
joedoc
Re: Fireface UC headphones not linked (outputs 7/8)
Maybe I should say that the problem is that there is a "PH" and PH." - separate levels for 7 & 8 ... not sure if that was actuall y there before... Same goes for the SPDIF - "SP" and "SP."
It's probably just a box that needs to be checked somewhere... anyone know?
In Ch. select mode, push the knob in for a couple seconds until the LED screen shows "on". That means stereo link is active.
Thanks Jeff! Especially answering on a Sunday!
Now that I think of it, a singer had pushed the knob in last session when trying to adjust something - that did it...
Always easiest to blame the singer anyway :-)
best wishes
joedoc
