Topic: Using a FF800 with a Mac and a PC alternatively
Hello
I have the opportunity to use a FF800 a friend owns
but he said that the FF800 was configured for his PC.
I would like to use it with my Macbook (Max OS X 10.6) without having to change anything about his FF is setup.
Will this be possible or does the FF800 have to be configured for either Mac or PC (Win)
Thanks a lot if someone can answer this.
Re: Using a FF800 with a Mac and a PC alternatively
No, the Fireface 800 works on both systems. Only the driver and the flash update program are OS specific.
best regards
Knut
thanks for the reply
Does this mean I have to flash update the device each time I want to either use it with the mac and then the pc and the reverse ?
If so there is an operation to be done on the device which I would rather avoid
There is no need to flash the unit. The firmware is cross-platform.
5 (edited by resume 2010-07-07 12:39:48)
Thanks a lot
So if I understand right I can just unplug it from the pc and plug it into the mac (after having installed the mac drivers) ?
Correct. Best to switch it off and on during the changeover. And if you want to be on the safe side, avoid hot-plugging.
7 (edited by resume 2010-07-07 13:09:55)
I will
thanks a lot !
