Topic: issues with HDSPe PCI card and Multiface II
Recently I bought by Thomann a Multiface II and a HDSPe PCI card. I installed the drivers downloaded on your site. My PC recognized the HDSPe PCI and it accepted the drivers but when I start my FUT, the process fails and it appears the message FAILED. When I do the same operation connecting my Multiface II to my HDSPe PCI card, I get the same issue, message saying "FAILED".
My HDSPe is a revision 1.3 with a Multiface II, connected with 12V external power supply and it doesn't match.
And Cubase doesn't recognize this sound card ! Can you help me please, it's very urgent !!!! Otherwise I must return the HDSPe PCI back to Thomann.
Joachim Depicker
Belgium
j.depicker@gmail.com
Re: issues with HDSPe PCI card and Multiface II
Which driver did you install? Did the settings dialog state it was necessary to update the firmware? What's the exact fut you used?
the drivers to install its those for Windows 7 that I found on your site HDSP_wdm_3085 it was used is that found at the same place fut_wdm_dspe
with the risk to appear idiotic, firmware = driver??
thank you very much for your speed!
regards
Joachim Depicker
Driver and firmware are different things. Is the driver correctly installed?
yes it is the driver!!! (.inf files in the zip package)
Can you open the settings dialog? Does it look normal? Or does it say something about "firmware mismatch"?
just
I/O box state
"error"
no "firmeware mismatch"
when i start the digichek
he learn to me "opening audio device : error number 4"
i dont understand
i have not a rme power suplie but a standard 12v dc! that's a probleme???
sorry y dont speek very good english
thank you for your answer!
my problem is not resolved i dont understand
and the time miss to my
y go back the soundcard to thomann this Monday if nothing is arranged
