Topic: Digital clocking question
Currently I am using the Fireface 400 with a digital preamplifier that has an AES-3 output. The preamplifier is connected to the S/PDIF input of the FF400. In this case, the FF400 is set to Autosync mode and preferred reference clock is set to S/PDIF, so the FF400 is slave and the preamplifier is master. This works very well.
I plan on getting an ADAT 8-input 8-output converter. Can I set it to slave mode, plug it to the ADAT sockets of the FF400, and everything will work correctly (still using the preamplifier as master clock)?
Best regards
-j
