Topic: Panning not unified (AN1+2) FF400
Hi.
I have routed on TotalMix my playback channels Out 1 + 2 to Outputs 1+2 (where my speakers are plugged).
my problem is that the meters show that Output 2 is 5-8dB lower than Output 1.
the meters on the playback channels are unified and panning is correct (R1L1) plus i have tried to play multiple programs to see if the root to the problem comes from there but that didn't help.
windows xp sound setting are correct too. HELP
Thanks !
2 (edited by Randyman... 2010-10-02 23:30:31)
Re: Panning not unified (AN1+2) FF400
Stating the obvious - Are you output faders linked - or at least set to the same exact level?  And are you in Submix Mode?
cool
2x SSL Alphalink MADI AX
Try loading a mixer factory preset. If the level imbalance is visible in the middle row of Totalmix, then it's happening in your audio software.
i'm not on submix and my faders are linked!
and there is no imbalance in the middle row of totalmix.
where can i find the factory preset for TM?
CTRL + Preset 1 button
You might WANT to be in Submix Mode.  There is a chance you aren't seeing the correct middle row "Destination" if you're not in Submix Mode.  I always use Submix Mode FWIW - it just makes Totalmix's vast power that much easier to manipulate IMNSHO...
Selecting the Preset should get you back to a known state as well...
cool
I tried everything you said and no luck sad
Where do you see the imbalance? Please upload/mail jpg screenshots of matrix and mixer.
Problem fixed! i reinstalled for the 2nd time the ff drivers and the imbalance disappeared.
Thanks for your help!
