Admin Knut wrote:Sorry no, this is a Windows limitation.
best regards
Knut
So this means this is a limitation for all USB audio-interface manufacturers on windows systems?
Just one idea:
Did you ever internal tested at RME to use your USB products with one ExpressCard/ USB 3.0 adapter? Does it makes sense at all?
The idea to this would be to use the fast pci express slot for the USB interfaces in USB 3.0 mode. Is this possible? Are there potentially Sample Buffer Size settings feasible less then 48 samples?
Like I said just one idea.
Thanks very much with best regards
Trommeltotti
