RME Support wrote:Broadcast versions have +6 dBU instead of +4...
Thanks for your answer.
Can you detail a bit more (not to be confusing) : Are both inputs and outputs have +2dB of headroom (means +21dBu max instead of +19dBu) ? I have to say that 19dBu max input is not enough for a lot of professionnal gear (my preamps can provide up to +24dBu max (@+4dBu nominal) and, sometimes more) and I must "under-modulate" preamps to fit AD dynamic range of my soundcard (Digi002Rack/ 18dBu max@4dbu nominal).
If I invest in external converters, I'd be glad to have more headroom on the inputs.
That's why broadcast version could be interesting to me...
[edit]
I finally found some info on the local Dealer website (SCV France) they're talking about additionnal 9db on the output (only ?) but it is not very accurate (does it mean outs at 19dBu + 9dB = 28dBu max ? or +13dBu max (+4dBu out setting) + 9 =+22dBu)
RME UFX - TM FX 1.05 / Drivers USB 2.03 fw 1.58
Mac OSX.8.5 / Pro Tools 10.3.10+11.3.1 / VEP 5.3.1
