1 (edited by AndreasN 2010-10-28 12:00:59)
Topic: Constant overload on ADAT 3/4
No matter what is connected, or nothing connected to ADAT.
I get this constant overload and the channels sounds bad.
http://i53.tinypic.com/imkvb9.png
This started visually with firmware 112 and driver 0.960. Out of the box firmware and Totalmix didn't show this and I never listned to the channels before the firmware update.
Should be better if I change to firmware 111 and driver 0.938 maybe?
Windows 7 x64
Gigabyte EP45
Intel Q9550
Corsair 4GB
Saphire HD5870
Intel SSD
Logitech keyboard and mouse sharing USB.
Cakewalk UM3G MIDI interface sharing USB.
EDIT: Fireface UC
Re: Constant overload on ADAT 3/4
It might be necessary to reset the mixer: Options, Reset Mix, Straight Playback with all to Main Out.
I tried to do a recording of it and now I dont even get bad sound only a little crackles.
The other ADAT-channels work fine.
I did the reset and nothing changes.
4 (edited by AndreasN 2010-10-28 13:15:13)
It shows better visually.
To the left a recording on ADAT 3/4 and to the right ADAT 1/2. Same instrument Yamaha DX7 and same MIDI-sequence.
http://i56.tinypic.com/6fyx7b.png
EDIT: Through SM Pro Q-ADAT, same thing with Alesis ADAT AI3. I can send audio to it from a Digiface also if you like, but I have to put in the PCI card first.
I installed 0.938 and it went away, installed 0.960 again and it stayed away.
