Topic: UFX Problem
Hi i have strange problem:
the analog inputs 7/8 are not working! there is no signal on the meters and no signal in any recording of these channels.
Is this a hardware fault or just a dsp problem?
when i switch the samplerate, the meters of channel 1-6 rise up but not the meters of 7/8.
sad
do i have to send it back to my dealer for guarantee?
Re: UFX Problem
No signal on the meters - are you talking about TotalMix FX Inputs showing UFL instead of -108 or so (self noise)? In that case the hardware is defective and the unit needs to be sent back.
Re: UFX Problem
Yes it shows Ufl instead of a Number. sad
I will send it back Tomorrow.
Re: UFX Problem
I have the same thing, but it occurs on inputs 3 and 4.  Also, I don't see any thing spike on channels 11 and 12, but they are registering self noise.
So the only resolution is to send the unit back?
