Topic: Babyface balanced output is NOT servobalanced
With the Babyface already on the road for delivery, I've got a question concerning the connection of my Babyface to my mixer (Yamaha MG 16-6 FX).
This mixer has balanced mic inputs (XLR) and unbalanced line inputs (1/4'' jacks). On the other hand, the two analog outputs of the Babyface (XLR) are NOT servosymmetric ("Die elektronische Ausgangsschaltung arbeitet nicht servosymmetrisch! Bei Anschluss unsymmetrischer Ger?te ist daher unbedingt darauf zu achten, dass der Pin 3 des XLR-Ausgangs frei bleibt. Eine Verbindung mit Masse f?hrt zu erh?htem Klirrfaktor!", cf. Babyface Manual v1.2, page 74).
So, I am wondering what the optimal connection would be:
1.) Use of two XLR mic inputs (2 x mono = stereo) of the Yamaha mixer? (What about the mic preamplifiers of the mixer? Is it possible NOT to use them? Gain setting = 0? Is the sound getting worse by this approach?)
2.) Use of the unbalanced line inputs of the Yamaha mixer? (In this case I would use an XLR-to-1/4'' jack adapter to plug in my balanced XLR cable? Is this a problem since the Babyface output is NOT servosymmetric?)
Any comments of the experienced studio users out there is highly appreciated!! Thank you!
P.S. I already own the unbalanced breakout cable of the Babyface. So I could use the Cinch connections. However, I would pretty much prefer to use my high-quality XLR cables (Vovox Protect XLR-XLR).
