Topic: FF 400 vs iMac
Hallo,
does the Fireface 400 still have problems with a iMac firewire?
I have an iMac (2009) and I would want to buy a Fireface 400 (or FF UC).
Re: FF 400 vs iMac
The FF400 does not have a problem, the iMac does. It depends on which FW chipset version you have on your iMac. You can use the instructions in the link below to check.
http://www.rme-audio.de/forum/viewtopic.php?id=4986
If you have the bad (Agere Rev 6) chipset, then the UC would be a better choice, IMO.
Re: FF 400 vs iMac
This is my iMac FW chipset:
kernel    FireWire (OHCI) TI ID 823f built-in now active, GUID 0026bbfffe52fbf2; max speed s800.
Is it compatible with FF 400?
Re: FF 400 vs iMac
TI firewire chipset should work fine with Fireface 400
check thread here
http://www.rme-audio.de/forum/viewtopic.php?pid=24531
regards S-EH
