1 (edited by mehmethan 2010-11-26 12:32:54)
Topic: Routing line inputs to line outputs, is there any AD/DA conversion
When I route a line input to a line output on Totalmix FX is there AD/DA conversion during this process ? or is it  pure analog signal routing ?
(example : input 1-2 routed to output 5-6  on totalmix fx  (no change on volume,pan,eq,reverb..etc.)
(I am planning to use Rme analog inputs & outputs as a regular patcbay)
Re: Routing line inputs to line outputs, is there any AD/DA conversion
mehmethan wrote:
or is it  pure analog signal routing?
If you meant "digital", the answer is yes...
Routing Analog with AD/DA yes conversion
but if you mean TotalMix inside (loopback)
then no AD/DA involved
I have not studied the new TotalMix FX or how it works
old FF 800 user
regards S-EH
Thanks for the replies.
So What I understand from your replies is :
1 ) Analog input -> AD -> Digital  -> DA -> Analog Output   (total mix routing)
2 ) Digital data of an output -->  digital data of an input (loopback)
Precisely.
