Topic: FF400 Problems Switching Sample Rate from Project to Project in SONAR
Hey guys!
I wanted to post about this a while back, but have been very busy. This all started with FF400 drivers 3.0.31, when RME added bigger buffers for Dual and Quad speeds in the settings dialog. Ever since then, SONAR 8.5.3 and now SONAR X1, stall when first loading projects that require a new Sample Rate (i.e. going from 44.1KHz to 96KHz and back). It takes something like 10 to 15 seconds everytime I load a project with a different sample rate, which gets annoying after a while. Project with similar sample rates load up normally. I've never had this problem before so I wanted to go back to the last working driver, version 3.028 I believe, but I can't. The most recent one in the archives is v.2.999, which may work for now but I wanted to go with something a bit more recent.
Two questions:
1) Are there any other SONAR users experiencing this issue?
2) How can I go back to driver v.3.028, which was working fine for me, until this issue is resolved?
Thanks!
