Topic: FF 800 routing help
Hi there,
I'm new about ff800 and total mix.
What I need is copy (routing) output 1-2 to output 5-6 to get the exact signal on both stereo output.
Thanks in advance.
Lorenzo
Re: FF 800 routing help
You don't need Totalmix to do that, insert some sends, set up a extra bus in your DAW and route that bus to whatever output:-)
Various ADK computers :-)
Assuming that you're trying to get 1-2 an 5-6 FF800 HARDWARE outputs to work with the same signal, just select 5-6 HARDWARE outputs in Totalmix(at the bottom row) and then raise SOFTWARE output channels faders(middle row) that are feeding your 1-2 hardware outputs.
Simples as that!
hope this help.
see ya
Yes, actually i was trying to get 1-2 an 5-6 FF800 Hardware. And it works!
Thanks a lot guys.
L
