Topic: ADI-8DS config for external sync via adat
Hi all,
Can anyone clarify what the correct config is of the buttons on the front of the ADI-8DS for use with an E-MU 1212m, with the 1212m as master clock? Litepipes hooked up both ways between the units.
I know that the D/A button should be on INPUT, but should the A/D button be on INPUT or INT? Presumably INPUT as well? I couldn't work it out from the manual.
"INPUT" on the A/D side makes little sense as there is no digital input on the A/D side, so presumably setting INPUT on the A/D section actually means the input of the D/A litepipe, the same as setting INPUT on the D/A section?
If the D/A is set to INPUT, and the A/D is set to INT, is that going to cause problems in a closed loop system like this one?
Thanks!
Gary.
