Topic: Connect Babyface to AES/EBU
I have an Apogee Mini Me D/A A/D converter , with AES/EBU connector. Can I connect it to Babyface?
Best regards
RME User Forum → FireWire & USB series → Connect Babyface to AES/EBU
Best regards
I'm not RME but own a Babyface, too.
If you want to connect it digitally, this cannot be done without a converter.
You would need to have a converter that has AES31 (AES/EBU) and optical Toslink SPDIF connection - and this in the right direction (you didn't write if you want to use the minime as input AD or output DA device).
Hermann
Thank you very much hermste,
I want to use Mini Me as input. Unfortunately it has coaxial spdif and aes/ebu ports only, no optical out.
Converters optical to coaxial SPDIF are easy to find and cheap, as they do not include active signal processing.
Thank you very much MC,
I'll look around for this converter
