Topic: RME9632, questions regarding TotalMix
Hi!
I'm a proud owner of HDSp 9632 for a several years.
Only now I've started using TotalMix and I've got few questions regarding it.
1). When I connect something to input I see the levels in hardware inputs. For example the guitar is connected through a mixer. Strumming it I hear the sound from my speakers, but the input is muted. It should be so? It's ZeroLatency technology engaged?
But when I arm the track for a record session in DAW I also hear the sound through my speakers...
Here is screenshot:
2). Question regarding the headphones output.
There is no "Ph(phones)" outputs in output section as it was example in docs. How their level could be adjusted separately with analog outputs? The Monitor Phones group haven't made any changes to it. Only main mixe's level made sense, but in such case the speakers level also is decreasing while I need a balance between speakers and phones.
3). As I understand in order to control the submix from a DAW you simply should route selected channel to 9632. For example selecting one of the represented out channels: STEREO ASIO HAMMERFALL DSP9632 ADAT1;3;5;7?
4). While, for example, playing music though a software player the hardware inputs meters shows the levels. As it is represented in screenshot. The inputs are muted, but if I raise the sleders the peeps occurs. It should be so ir something is wrong?
Thank you!
