Topic: MADIFaceXT crashes Protools 11 HD
Hi there, I have owned a MADIFaceXT for a few months now and have tried a few times to get just the analogue inputs into Protools to record. When I select the MADIFace as the playback engine it will connect but randomly (more than not though) it will cause pro tools to crash either straight away or when assigning an analogue input to a track. I haven't yet had opportunity to check this with MADI inputs. Has anyone else had this problem?? also, regarding the 48v phantom indicators on the front of the unit, Analogue input 1 indicator does not light up? anyone else had this problem too??
Many thanks in anticipation
Christian
I'm using a MacBookPro with a Belkin Thunderbolt expansion to USB3 setup. I have tried it as USB2 with the same results
Re: MADIFaceXT crashes Protools 11 HD
Hi Christian
Same problem here! Same setup!
MBP Mid 2012 OSX 10.9.1
PT11HD 11.1.3
Madiface XT Firmware v 167 - Driver v 1.95
Protools crashes after telling me: "IO channel count for current playback device has changed. Please restart Pro Tools."
Did you get it fixed?
Patrick
Not yet, but noticed this morning that there is a new version of Pro Tools 11 11.1.3 but see you have put that as your current version....
Will try again this morning with new version and see what happens!
Cheers
Updated to PT 11.1.3 this morning only because of same crashes with 11.1.1.
No luck.
Will contact Avid as well.
Best, Patrick
Still the same for me unfortunately! I even tried with just a USB2 connection but as soon as I assign inputs or outputs to tracks in protools it crashes!
This is very annoying!
Hope they can sort it soon!
Cheers
Christian
I'm having the same issue with Pro Tools HD 9.0.6 on OSX running native with the Madiface XT. If I try to switch the playback engine to Madiface XT, PT crashes. It works with "built in audio".
Has this been resolved at all, or is it a known issue?
Thanks,
TC
7 (edited by TC 2014-11-18 02:44:22)
Does anyone from RME even read these forums? I guess this is not the place to try and get answers or help from them.
Still crashing here. Can't switch the audio engine to the Madiface XT without PT9 crashing every single time. Preferences have been trashed, PT has been reinstalled, etc. No luck.
If you were to search this forum, you would likely find out that the crashes in PT 9 are a known issue of the software. There is nothing we can do about this. The problem was fixed in later versions of PT and should be a thing of the past in 11. Whether or not the cases in this old thread are a return of the old bug (or even still exist today) remains to be seen. In any case, they are not related to the known PT 9 crashes (which are apparently due to the number of channels of the XT, and the software being unable to handle that).
I just want to be clear that this is the type of support response that RME is going with? Or am I somehow interpreting this incorrectly as being extremely flippant? I will admit my last response was snippy, but given the circumstances, I'm sure you can appreciate the level of frustration here. I certainly don't expect you to respond in kind, but good to know that this is what end users can expect from RME.
First, if I do a search for "Madiface Pro Tools Crash", I primarily get this thread, which is what I was searching in my attempts to determine if this was a known issue (and yes, FYI I did multiple searches over several days). http://www.rme-audio.de/forum/search.ph … 1591129976
Searching off this site on google today did returned this thread, which I had not seen before: http://www.rme-audio.de/forum/viewtopic.php?id=15766
Second, when making a 3k + investment in the Madiface XT, my dealer was not informed that it does not work with ProTools 9/10, and nor was I when making the purchase, so I'm not quite sure why you feel that the burden is on the consumer to somehow know this? One would assume that a new top quality interface such as the MadiFace XT would indeed be compatible with Pro Tools software.
Please explain to me where in your literature on your website or in the manual (which I have read thoroughly), it notes that Pro Tools 9 (and apparently 10) are not compatible? http://www.rme-audio.de/en_products_madiface_xt.php
I have no plans to upgrade to Pro Tools 11 and buy into Avid's new subscription plan, but I do still have a license for PT9 HD, which would be nice if it worked. I understand if this is an Avid issue, but it seems to me that making note of this compatibility limitation on the MadiFace XT product page would be a good idea, no? This would help potential customers avoid headaches and make sure they won't run into compatibility issues.
10
If you use the XT via USB it might help to limit the unit to USB2 mode and with this to 64 channel I/O (I think the old 9 crashed above 32 channels...). Using the XT via E-PCIe the driver allows to reduce the number of WDM devices to 0 and the number of ASIO channels to 32 (added June 2013 for PT).
Please mind that the compatibility issue here is clearly on the Avid/PT side. PT 9 and older versions of PT 10 have a known issue that causes them to crash in the presence of such channel numbers. This was fixed eventually, but there is nothing we can do, channel limits aside), and I see no need to post information about "compatibility issues" with outdated and buggy PT versions, to be honest. In any case, you will not be able to use more than 32 channels anyhow, which is another (deliberate) Avid limitation when using PT with non-Avid hardware.
Wow. You see "no need". Ok. Even though it is indeed an Avid issue, one reason to post information about "compatibility issues" would be simply as a courtesy to existing and potential customers of the Madiface XT. If this was noted, it would have personally saved me hours of troubleshooting time with my system trying to figure out why it was crashing, reinstalling software, drivers, etc. Apparently your customers' time is not deemed valuable enough to post a couple of lines of text on your website or in the manual for users of Pro Tools 9/10 (not exactly an obscure little used daw)? Good to know.
It's interesting that I was able to find info on this fairly quicky on SSL's docs for their MadiXtreme cards, and they did even implement a workaround for their customers. Apparently they did see the need for this.
http://www.solid-state-logic.com/suppor … nloads.asp
New in MadiXtreme Driver V1.3
Fully certified for Mac OSX 10.7 (Lion)
Includes new Firmware V19 with several performance improvements
New MADI Channel Limit (MCL) functionality, set in MadiXtreme Control Panel by clicking on the "MADI Channel Limit" Button (reboot required)
Applications for MCL:
Pro Tools 9/10 Users. As PT 9.x and 10.x can only work with an Audio Device of max. 64 I/O Channels, setting the MCL to 32 Channels on a MadiXtreme 128 will allow this card to work
Limit to 32 Channels for MadiXtreme 128 Users, that work in 96 Khz (no "blank" Core Audio I/O's, ie. 33-64)
Limit to 48 Channels for Alpha-Link Users (also for Users with 2x Alpha-Link...avoids "blank" channels as well)
Apparently SSL thought enough of their customers to at least note the issue.
My Madiface XT replaced a system with 2 Lynx AES16e cards with an additional LS-adat daughtercard, which was capable of more than 32 physical i/o. While the physical i/o may have been limited to less than this in PTHD 9 software, Pro Tools was not crashing on startup with this setup. (I also don't believe that an "HD" license is limited to 32 "channels", as you've stated).
I wil likely upgrade to PT 11, but this type of response towards your customer base has certainly left me with a less than positive perception of RME.
I would suggest that while this is certainly an Avid technical issue, your disdain towards them should not be passed down to customers who've invested in your products. Simply noting the issue (as SSL have done) would have gone a long way towards avoiding that.
In any event, I do thank you for your responses.
It is remarkable that you do not seem to consider Avid as a potential source of information on such issues of their own software. Is there a specific reason for that?
The fact of the matter is that this was really not a "compatibility issue" at all to begin with. It was a bug in PT. Therefore, the information on the SSL website is partly incorrect, since this bug was fixed in later versions of PT 10 (not in 9, though). Therefore, I would maintain that there is little to no need to post information on our website about an issue that is fixed in one version of PT and only affects another that is two versions behind the current one. Information about issues like this ought to be available on the Avid website.
That aside, what we did went well beyond posting information about "compatibility" on our website - we actively worked with Avid to help them identify and fix the issue in PT 10, e.g. by providing them with hardware for testing. I don't think that qualifies as "disdain" in any way - neither for Avid nor our own customers...
As for the 32-channel limit with third-party hardware, I must admit the information about which version of PT (HD vs. non-HD) may or may not have it doesn't seem to be perfectly clear to me, or at least I've heard conflicting reports, also of impending changes. You may need to check with Avid to be sure.
14 (edited by TC 2014-12-01 21:43:44)
And I find it remarkable that you are being so contemptous with me, considering I am a long time RME customer, and I think the points I've made are quite valid and not at all unreasonable or illogical. Clearly you feel in this case that the "customer is always wrong". That's fine.
To answer your first question, PT immediately crashed after installing and setting up the MADIface XT. Prior to that, I was using 2 Lynx AES16e cards (72 channel I/O configuration with no issues). Naturally I first looked for answers on RME's end, as I had assumed I could find answers if there was a compatibility issue with the most commonly used software in North America for post production and studio work. (Due to the large number of interfaces and soundcards available, this is a more likely source of info, as Avid is generally not going to list every interface available).
Apparently I was incorrect in this assumption. I also find in funny that I only received a response in this thread after making a comment questioning RME's support, rather than to the support inquiry itself.
Had you originally replied and said, "yes, it is a known issue", that would have answered the question.
You keep repeating the fact that it's a bug in PT. I UNDERSTAND. WE ALL GET THAT. THAT IS NOT IN DISPUTE. SSL GETS THAT AS WELL. THEY STILL NOTED IT.
You said you went above and beyond, helping avid identify the issue. Yet, you wouldn't spend 5 minutes to make a note in your docs to potential customers as SSL did. That's all I'm saying. Would have been nice.
You clearly have no perspective from the customer side of things.
Allow me to ignore the accusations and allegations and just to post one final reply with a few more facts.
This issue was clearly not specific to individual interfaces.
Had I said so, my answer would have been incorrect. I clearly stated that there was a known bug in certain PT versions and that I was currently not aware of such a bug or another one of similar nature having (re)surfaced in PT 11.
We will certainly not post notes on "compatibility issues" of or with any third-party software on our website while we are currently in the process of helping its manufacturer identify and fix the issue (and successfully so). The RME forum is a place where such temporary issues can and will be discussed. Moreover, we won't leave such "information" on our website long after the bug has been fixed. It would have also taken SSL five minutes to check and correct the note concerning "compatibility" of PT 10.3.x (not sure which version number exactly fixed these crashes, I have 10.3.7 here running on OSX 10.7.5, later OSX versions on my Mac have already been upgraded to 11, with no known issues so far). Instead, the partly inaccurate information remains on their website and you do not seem to find that noteworthy.
Why Avid have chosen not to fix this in PT 9 is another matter and beyond our influence, I'm afraid.
16 (edited by TC 2014-12-02 00:06:50)
Yes, Daniel, let's leave it at that. We can agree to disagree on posting "notes" regarding known issues. At least SSL's notes err on the side of caution, if this was indeed resolved in later 10.x versions. (I have no real issue with their notes, as I haven't invested 3.5k in their cards).
I'll admit that your first response implying that I somehow didn't "search the forum" set the tone for me for our entire exchange.
I'd ask that you maybe try to see things a little bit more at times from the end users perspective. I understand you are tech support, but that would go a long way.
Have a nice week. I do appreciate your help by the way, and I now know that I need to upgrade to PT 11 to use PTHD.
Here's an update from Avid - an issue has been identified after we notified them of a potential issue and a fix should find its way into PT11 soon. We will also test it as soon as we get the update.
Hi, I also have a similar problem. I have a Madiface XT, which crashes when opening PT 11, PT HD 11 and PT HD 12. I am a long time RME user but this is the first time I register for this forum because is my first problem of this kind (also owned Fireface UFX, Madiface and older products).
I know what i can expect from a company like Avid, and what to expect from RME. That's why I really believe the only solution can come from RME's side. Either limiting the channel count with a special driver, or whatever you can think of.
Please let me know when you solve this problem. I really like my Madiface XT but my clients rely on Pro Tools so now I'm using another interface, which is a shame considering the thousands of dollars that it costed.
Thank you
expectations and assumptions will not help here. This is undisputedly an Avid/PT issue, as confirmed by Avid. It has been fixed in PT 10.3.7, but apparently crept back into 11 and now 12. Whether or not (and when) there will be a fix for 11 now that 12 is out is something only Avid can tell you.
The HDSPe FX driver provides a 32-channel ASIO limit option. But this can be no more than a workaround, because it will also affect other software. Also, it won't help under OSX, of course.
Please be assured that there is no way we can actually "fix" or "solve" this. Any RME interface with fewer channels (all HDSPe cards, all Firefaces) is not affected.
RME I HOPE YOU KNOW YOU ALL ARE THE ONLY ONES HAVING THAT ISSUE, I have a very good friend that work for avid and they say the issue if from you all. This 32 channel limitations is you not AVID. I have a UA Apollo and with Pro Tools no HD i can do up to 124 channels with no issue, i have tested other interfaces from SSL and also don't have that same issue. I also have a RME MADI for my Neve and other then crashing once in a blue it also has a limitation of 32 channels so i will be switching to focusrite Red. RME you all have a great sounding product but its sucks with Pro Tools..
Hi a, having the same issue - and would like to know if this is EVER going to be fixed.
My Configuration is OS X 10.10.5 - Ant the latest Protools 11 HD License. And the RME MADI FX Card
I have Protools 10 Co-Installed - and that works - but there is this ugly graphics bug with the i/o's and inserts not displaying correctly.
The latest posts are quite old and meanwhile we already have PT 12 - So i would like to know if this issue was fixed in the meantime - and if there is any information about Protools 12. I have noticed that the fault was given to avid - and noticed the harsh tone - Actually i also don't really understand, why this cannot be fixed with an updated OS X Driver or firmware, where all the channels beyond 32 are hidden. Looks like other companies have managed that.
And since i consider RME an absolutely top-notch company - That is really quite surprising ...
Please Let me know of any relevant information
Thanks Luigi
Same problem here too - with the Madiface XT on a Mac with the latest version of Pro Tools 11.3.2.
Record-enabling a strip with an input set to channel 1-64 is fine, but arming anything above channel 65 causes PT to crash. A tad annoying if you want to arm any of the mic inputs or the AES input by itself - or indeed MADI 3 which is the only coax IO - as they come at the end after all the MADI streams!
Confusingly it's happy to output channels 65 upwards, just not input. Is there any news in the works?
23
Workaround: use the XT in USB 2 mode which reduces the number of channels to one MADI port.
24 (edited by ckalcov 2015-10-21 16:42:13)
Can you select which MADI port (or other channels) in USB2 mode?
Otherwise it seems happy to work over USB3 for MADI port 1 anyway (or MADI ports 1+2 when at 2Fs).
CK
25
Via Mirror and Redundancy options you can use both optical or coaxial I/O.
Well this is brilliant. After not using PTHD software since purchasing the Madiface XT, I went and upgraded today before the month end deadline. Specifically so I can have session compatibility and finally use my RME unit with PTHD again (I've been primarily using Cubase/Nuendo), since "apparently" it was Pro Tools 9 HD that was the problem last time I visited this thread.
Of course when I open PT12 HD for the first time, I'm getting "I/O channel count has changed... restart pro tools..." and crash.
I see this is still an issue, and I'm happy to learn that I've just wasted $600 doing an upgrade to the latest PT12 HD version. Lovely...
I do this for a living. It would be nice to have this expensive RME interface actually work with the most widely used software in the recording profession. By the way, I love this page, it's steeped in irony - http://www.rme-audio.de/en/news_rme_ind … andard.php
Any suggestions guys, or is this a lost cause? USB 3 is not an option here, thanks. I'm on a 12 core 2010 mac pro tower, all slots are full.
Also, I like how you still are not putting any Pro Tools compatibility issue notes on your product page. Avid also doesn't have the Madiface in their "will not work" list. I guess it's still the customers fault, or Avid's, or God's... or whatever.
27
Apparently not, as I've learned today. Same issue in 12 (at least 12 HD).
As it were (or should I say ironically?),  PT 12.3.1 works just fine here with the Madiface XT in OSX 10.11. We also recently had a customer who had an issue similar to yours on two of four brand new iMacs, while it worked on the other two. Last I heard was that they copied disk images from the working systems to the other ones, and that fixed it. What exactly may have cause the issue is not clear, unfortunately. It may indeed be neither Avid nor RME. Without clear reproducibility on our systems, it will be hard to find the cause, much less simply fix it.
Please mind that this is really not an issue of the XT "actually work(ing) with the most widely used software in the recording profession". There is no specific criterion for PT compatibility. PT Native uses standard ASIO and Core Audio drivers. If the issue were driver related, it would affect other software as well. All earlier issues of this nature were eventually fixed by Avid. Limiting a driver's channel number can only be a workaround at best, and once the actual issue is solved, it becomes redundant. There is also no apparent need for "compatibility issue notes" on either our or Avid's website. I would still suggest you contact Avid to find out what may cause this error message, they will know best.
If not USB 3, how is your XT connected? For USB 2, try manually setting the device to USB 2 mode instead of "Auto". I have it running on USB 3 here, on a 2010 2.8 GHz Quad Core.
If your system can not host an additional USB 3 card, that is, well, not within our scope of influence...
Have not tested PT 11 in a while, but can do so in a moment.
29 (edited by TC 2015-12-21 09:02:54)
Hi Daniel,
Thanks for the reply. I'm running 10.10.5, PTHD software 12.3.1. My XT is connected using the external PCIE port with a Sonnet card, in a 2010 Mac Pro tower.
Did you ever have the XT working on an OSX version under 10.11?
What I can tell you from researching this a bit is that UAD has written a custom PT driver for the Apollo, and I believe that SSL did that as well in order to work with PT.
I will contact Avid, since I now have a 1 year support contract. We can go back and forth on this for another year if you like, but it still amazes me that you don't have notes about this on the XT product page, and that you don't see a need for that. It's beyond me... Avid do list interfaces that "do not work" on their website, so I'm not sure what your point is. It may be an Avid issue, but since you are claiming RME to be the "Industry Standard", then don't you think it's important to have these XT interfaces work with the "Industry Standard" daw? If that means writing a custom driver that limits channel count (like LYNX and UAD do), than so be it if that's what it takes. It may be a "workaround", but if it gives me the ability to actually work, then I'll take it.
In the meantime, any additional testing or info you can provide would be much appreciated.
Cheers.
30
By the way, just so you don't think I'm being completely negative here, I absolutely love the XT with Cubase/Nuendo. It's fantastic in every way, except when it comes to Pro Tools...
With PT? Not sure I tested the XT, might have been the HDSPe MADI FX. But I do recall the multichannel issue was fixed in the latest version of PT 10, but may have crept in again later, i.e. in 11. PT 12, however, does in fact show me the same message in OSX 10.10. Not sure whether that is because of the earlier presence of PT 11.
I take that as a figure of speech, not as a clear definition of what it takes to "work" with PT...
As the other case I quoted goes to show (the four iMacs), there simply does not seem to be a general issue that would warrant some kind of compatibility note or statement of PT and XT not "working" with each other...
No such workaround required on my system, or on that of the other customer I mentioned...
And as for "industry standard", both sides use standard drivers, Core Audio and ASIO. That should really be all it takes, and as you observe, other DAW software works just fine.
You can find out whether it is related to OSX by installing 10.11 onto a new partition (don't just update) and then trying PT 12 again.
Hi Daniel,
I've had some success here testing some things since my last post, so maybe you can also test this out as well to confirm...
First, hold down the "N" key before launching PT. Then in the dialog window, check the "Ignore Errors During Playback/Record" box. Make sure Madiface XT is also selected as the playback engine (sometimes defaults to core audio).
That's working for me. I haven't tested yet with recording/playback, but I can now get it launched, and see all 196 inputs and 198 outputs in my I/O configuration, all checked and enabled.
Will do further testing, but this is good news so far!
Hopefully this helps the other people here who have also been having these issues.
Cheers.
TC
Hi everybody,
Unfortunately this does NOT fix the Problem i have with PT12.3.1. and the Madi FX ...
see my last posts here:
https://www.forum.rme-audio.de/viewtopic.php?id=15766
As soon as i select any I/O > Ch 32 i got crashes...
If anybody with Protools 12.3.1 /Madi FX(in a sonnett TB chassis) on El Capitan can reproduce & share this i´d be glad.
thanx,
Nik
Update:
Same behavior with PT 12.4.0........downloaded and installed 5 min ago........
35
Hallo,
please try enabling the "Ignore Errors During Playback/Record" function in the Pro Tools Playback Engine dialog. This actually resolved the "IO channel count changed" problem with PT & Madiface XT on two independent machines in our studio.
https://dl.dropboxusercontent.com/u/9334460/pt_ignore_errors.png
Jakub
I had luck running PT on system without problems, then backed up and loaded settings on another Mac using ProTools Prefs Helper v 1.6.12 (it's important to use same version of this tool for both backup and restore),
also I noticed the problem most likely lies in "ignore errors during playback/record" in PT 11.3
HDSPe AIO, ADI-2 DAC, Fireface UFX, Octamic D, Octamic II
Reaper, Windows 11, M2 Studio
