RME Support wrote:Please mind that the compatibility issue here is clearly on the Avid/PT side. PT 9 and older versions of PT 10 have a known issue that causes them to crash in the presence of such channel numbers. This was fixed eventually, but there is nothing we can do, channel limits aside), and I see no need to post information about "compatibility issues" with outdated and buggy PT versions, to be honest. In any case, you will not be able to use more than 32 channels anyhow, which is another (deliberate) Avid limitation when using PT with non-Avid hardware.
Wow. You see "no need". Ok. Even though it is indeed an Avid issue, one reason to post information about "compatibility issues" would be simply as a courtesy to existing and potential customers of the Madiface XT. If this was noted, it would have personally saved me hours of troubleshooting time with my system trying to figure out why it was crashing, reinstalling software, drivers, etc. Apparently your customers' time is not deemed valuable enough to post a couple of lines of text on your website or in the manual for users of Pro Tools 9/10 (not exactly an obscure little used daw)? Good to know.
It's interesting that I was able to find info on this fairly quicky on SSL's docs for their MadiXtreme cards, and they did even implement a workaround for their customers. Apparently they did see the need for this.
http://www.solid-state-logic.com/suppor … nloads.asp
New in MadiXtreme Driver V1.3
Fully certified for Mac OSX 10.7 (Lion)
Includes new Firmware V19 with several performance improvements
New MADI Channel Limit (MCL) functionality, set in MadiXtreme Control Panel by clicking on the "MADI Channel Limit" Button (reboot required)
Applications for MCL:
Pro Tools 9/10 Users. As PT 9.x and 10.x can only work with an Audio Device of max. 64 I/O Channels, setting the MCL to 32 Channels on a MadiXtreme 128 will allow this card to work
Limit to 32 Channels for MadiXtreme 128 Users, that work in 96 Khz (no "blank" Core Audio I/O's, ie. 33-64)
Limit to 48 Channels for Alpha-Link Users (also for Users with 2x Alpha-Link...avoids "blank" channels as well)
Apparently SSL thought enough of their customers to at least note the issue.
My Madiface XT replaced a system with 2 Lynx AES16e cards with an additional LS-adat daughtercard, which was capable of more than 32 physical i/o. While the physical i/o may have been limited to less than this in PTHD 9 software, Pro Tools was not crashing on startup with this setup. (I also don't believe that an "HD" license is limited to 32 "channels", as you've stated).
I wil likely upgrade to PT 11, but this type of response towards your customer base has certainly left me with a less than positive perception of RME.
I would suggest that while this is certainly an Avid technical issue, your disdain towards them should not be passed down to customers who've invested in your products. Simply noting the issue (as SSL have done) would have gone a long way towards avoiding that.
In any event, I do thank you for your responses.
