Topic: Running ADI-648 ADAT I/O at 96k
I've decided to work at 96k rather than 48k that I used to work at. I have the MADI I/O on my ADI-648 working at 96k but the ADAT ports I use, which are connected to an Eventide H8000 is causing a problem. The Eventide is reporting a sample rate of 48k, rather than 96k. Do I need to do anything extra to make the ADAT I/O run at 96k ? The H8000 is capable of 96k and runs fine using Wordclock input, but when it is clocked off the ADAT in (from the ADI-648) it says 48k.
