Topic: Raydat Adat "Sync-Clicks"
I hear some strange "Clicks" when I record some stuff through my Midas XL48 Preamp.
The preamp is via Adat connected to the Raydat. On the preamp the settings are 44khz, Internal sync.
In the Hammerfall DSP Setup Window the Input Status of the Adat4 jumps always from "Sync" to "Lock" and back to "Sync" every 5sec. Always when I see changing the status I hear also a click/noise sound.
Can please someone explain it to me what this is and how I can avoid it?
I uploaded a soundfile here where you should be able to hear this strange "sync clicks". The clicks are only hearable if I play or record something. If the Inputs are not in use without signal there are no clicks.
http://www.nicelabs.at/tmp/rmeRaydat_Mi … cClick.mp3
(First click is after 7sec)
