Topic: Hidden settings tab in Win 7
I have a problem with the settings tab under the windows 7. After the installation 4.04 driver I can not open the settings window even if it is possible to open the TotalMix window. This is quite disturbing as I can not change any setting even the clock or buffer size. The driver seems to work and is installed fine.
Does anyone have met the similar situation?
