Topic: TotalMix FX Feature Suggestions
1) In the Matrix some controls cannot be accessed when the window size is too small. Consider enforcing a minimum window size, filling empty surrounding areas with solid black or dark gray.
2) Combine "Preferences" and "Settings" into a single window (e.g. add an extra tab?). Having "Settings" and "Preferences" is very confusing, even for RME staff, for example, the manual for the Fireface UCX says "Preferences" but it's actually "Settings":
Talkback: A click on this button will dim all signals on the Phones outputs by an amount set up
in the Preferences dialog. At the same time the control room's microphone signal (source de-
fined in Preferences) is sent to the Phones. The microphone level is adjusted with the channel's
input fader.
3) Why not have the mixer app respond to a global keyboard command so that we can adjust volume without resorting to third party hacks?
4) The manual and the GUI use the term "MIDI Control" incorrectly, it should be MIDI Controller or MIDI Device. "MIDI control" refers to a knob or a fader, whereas a MIDI Controller is a whole device with several faders, knobs and buttons.
5) Use the same terminology to refer to a feature everywhere. In the GUI and user manuals different words are used to mean "MIDI Controller":
"Submix linked to MIDI Control" should read "Submix linked to MIDI Controller"
"MIDI Remote 1/2/3/4" and "OSC Remote 1/2/3/4" should read "MIDI Controller 1/2/3/4" and "OSC Controller 1/2/3/4"
The listview header "Remote" should read "Controller" or "Controllers" or "Controller(s)"
"Index" should read "MIDI Controllers", and "OSC Controllers" on the OSC tab.
Actually, the choice of words doesn't matter, either "Controller" or "Remote" is good but the point is: it better to use the same terminology throughout. Thanks!
