Topic: Fireface 800 stopped to show up in Control Panel -> Sound
Yesterday my RME Fireface 800 disappeared from Control Panel -> Sound -> Playback/Recording. It means I can't listen to windows apps through my main soundcard. The other cards (Virus TI, and Realtek HDA which is turned off) shows and works OK. The card WORKS OK under ASIO mode. The "Fireface settings" window works also. I can change the sample rate, phantom power, etc. The TotalMix shows inputs and outputs with corresponding signals (=dB). I can use the TotalMix window (sliders, etc.). The MIDI Control of TotalMix works also. MIDI I/O ports works as well and are visible from the DAW.
The Device Manager displays RME Fireface without any error or warning and says that "This device is working properly".
I tried to reinstall the driver (installing the driver over the current installation as well as deinstalling "RME Fireface" and "Pakiet sterowników systemu Windows - RME Fireface (06/09/2015 3.1.15.0)" (translates to something like "Bundle/Package of Windows drivers - RME..."), then reboot, clean install, reboot), nothing changed.
I removed the VIA FW controller and replaced it with Texas Instruments FW controller, nothing changed (except for TI driver installation of course).
I turned off the Virus TI, plugged it off, nothing changed (except for Virus disappear of course).
I did a lot of reboots, with turning off the card, whole computer, etc., nothing changed.
My Fireface settings about screen says I'm using driver dated 09.06.15, version 3.115 on hardware revision 2.77.
The card works OK on Mac at first glance.
I use 64-bit Windows 7 on the PC. (i5 @ 3.3, 16 GB RAM, etc.)
TIA for any help!
