1 (edited by riffwraith 2016-01-14 19:46:32)
Topic: HDSPe AIO works at 48k, but not 441
Hi all.
W7 Ult 64 SP1, fully updated. HDSPe AIO PCIe, driver vers: 412 (is that the latest - where do I find the latest drivers?)
When the card is set to 48k via the DSP settings, all works as expected. When the card is set to 441k, I still have audio in Cubase, but no audio elsewhere (web, playing audio files from my HDD with a 3rd party app, such as WinAmp, VLC).
Was hoping someone can tell me what it is I am missing?
Thanks in advance.
Re: HDSPe AIO works at 48k, but not 441
The Sound control panel where you have to set the AIO as default playback device.
Thnaks.
Ok, I just had a look at the sound  control panel - I no longer see Analog (1&2) as I once did, in the  playback tab. It's there in the recording tab.
Where'd it go?
It's called Loudspeaker.
5 (edited by riffwraith 2016-01-15 17:54:38)
I don't see anything called Loudspeaker.
I did, however, see Analog (1&2) - or at least I think I did...
I do have something called Speakers. That is in fact set to default device.
Problem solved. I loaded a prior image, and it's fine. Not sure what happened, tho...
Maybe you did disable the WIndows Audio service!?
