Topic: clics and noises using word synch on Hdspe AIO / Fireface400 in 24/96
Hi there RME users and admins !
First time here for me even tho i am a RME user since at least 8 years. Pls excuse my incorrect English not my native language.
I have set up a new configuration latetly to be able to mix a new project on 12 separate outputs into a summing mixer. I love it compared to ITB mixing.
My problem is that i followed everything both in AIO manual and Fireface manual to set my synchro between the 2 interfaces but i can still hear very annoying randoms clics thru my speaker.
I purchased the 4 outputs extension + wordclock card for the AIO and connect the AIO master wordclock thru a 75ohms cable to the wordclock input of my slaved FIREFACE400.
I did the same with SPDIF coax out from AIO into spdif coax in on the FF400,
and i did the same with ADAT optical out from AIO into ADAT optical in of the Fireface400.
All good, the input status on the Fireface 400 reads SYNC for both Word and SPDIF and it blinks SYNC/LOCK for ADAT.
Also on the SPDIF input line of the FF400 i can read 96000 HZ;
So, can someone please explain to me what is wrong here? Why do i hear clics?
When i open both TotalMix (the AIO one on PC and the FF400 one controlled by laptop) i can see that the clics are sent by the AIO via ADAT1/2 and ADAT3/4 to the same ADAT input on the FF400.
Please help if you can, i have so much mixes to do and i am blocked at the moment.
Thank you
edit: my buffer and sample rate settings are exactly the same on both cards
