here is the crash log analysis:
Welcome to WhoCrashed (HOME EDITION) v 5.51
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue (or black) screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue (or black) screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which allows you to perform more thorough and detailed analysis. It also offers a range of additional features such as remote analysis on remote directories and remote computers on the network.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
Computer name: DESKTOP-D436CEK
Windows version: Windows 10 , 10.0, build: 10586
Windows dir: C:\Windows
Hardware: Z170X-UD5 TH, Gigabyte Technology Co., Ltd., Z170X-UD5 TH-CF
CPU: GenuineIntel Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 34234347520 bytes total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 27.06.2016 15:59:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062716-3765-01.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x1A (0x61948, 0x125EC8598, 0x1, 0x125EC8598)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
On Sun 26.06.2016 02:19:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062616-3781-01.dmp
This was probably caused by the following module: madiface_usb_64.sys (madiface_usb_64+0x63AD)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF802E6CCFA9D, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\drivers\madiface_usb_64.sys
product: Windows (R) Win 7 DDK driver
company: RME
description: MADIface USB Audio Driver (WDM)
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: madiface_usb_64.sys (MADIface USB Audio Driver (WDM), RME).
Google query: RME KMODE_EXCEPTION_NOT_HANDLED
On Sat 25.06.2016 20:23:29 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062516-3593-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80158AC7A9D, 0x0, 0xFFFFFFFFFFFFFFFF)
company: RME
On Sat 25.06.2016 15:56:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062516-3531-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF802F653AA9D, 0x0, 0xFFFFFFFFFFFFFFFF)
company: RME
On Sat 25.06.2016 02:28:09 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062516-4921-01.dmp
Bugcheck code: 0xA (0x3, 0x2, 0x0, 0xFFFFF8023E2DAA9D)
Error: IRQL_NOT_LESS_OR_EQUAL
company: RME
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
Google query: RME IRQL_NOT_LESS_OR_EQUAL
On Sun 19.06.2016 11:17:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061916-4203-01.dmp
Bugcheck code: 0x1A (0x61948, 0xED90A598, 0x1, 0xED90A598)
On Wed 15.06.2016 22:36:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061616-3640-01.dmp
Bugcheck code: 0x1A (0x61948, 0x19CBD7598, 0x1, 0x19CBD7598)
On Tue 14.06.2016 10:44:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061416-3781-01.dmp
Bugcheck code: 0xA (0xEE66, 0x2, 0x0, 0xFFFFF80234EE2A8D)
company: RME
On Tue 14.06.2016 06:13:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061416-3546-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF801178DAA8D, 0x0, 0xFFFFFFFFFFFFFFFF)
company: RME
Conclusion
51 crash dumps have been found and analyzed. Only 10 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
