nelson_a wrote:MC wrote:The website of the ADI-2 Pro is currently under work as the number of I/Os is not easy to get, I agree with that. Please simply read the unit's manual and you will understand why it is a true 6 in / 8 out device with 2 in / 4 out on analog. BTW, where is this unit sold for $2,300?
Just to clarify, when you say 2 in / 4 out, you really mean 2 in / 2 out (balanced) and 2 out (unbalanced), correct?
The way I understand it from information on web (analog part)
http://www.rme-audio.de/en/products/adi … 0403485800
2 IN servo-balanced (XLR or TSR, combi plug),
2 OUT (XLR, balanced) and 2 OUT (TSR, unbalanced) both useable, as you have separate XLR/TSR plugs.
Pls see here in short, hope it helps (also good to look at the rear of product picture at the same time):
Analog Inputs
XLR
• Input: XLR, servo-balanced • Input sensitivity switchable +24 dBu, +19 dBu, +13 dBu, +4 dBu @ 0 dBFS
TSR
As input XLR, but:
• Input: 6.3 mm TRS jack, servo-balanced
Analog Outputs
1/2 XLR
• Output level switchable +24 dBu, +19 dBu, +13 dBu, +4 dBu @ 0 dBFS
• Output impedance: 200 Ohm balanced, 100 Ohm unbalanced
1/2 TS (rear)
As output XLR, but:
• Output: 6.3 mm TS jack, unbalanced
Phones 1/2
As Output 1/2 TS, but:
• Output: 6.3 mm TRS jack, unbalanced, stereo
Output Phones 3/4
As Output Phones 1/2, but:
• Output levels at 0 dBFS: Hi-Power off +7 dBu, Hi-Power On +22 dBu
Balanced Phones mode
As before, but:
• Output levels at 0 dBFS: Hi-Power off +13 dBu (9.8 V), Hi-Power On +28 dBu (19.5 V)
