Topic: HDSP 9632 - More Analog I/O's needed for 2nd monitor (suggestions)
Hi again Guys,
Getting on my feet now with new HDSP 9632. I want to get cleanest signal from Outputs direct to Monitors. But only having one pair of Analog Out I'm stuck when A/Bing on 2nd Monitors. I was using a Mackie 1202 to split out the signal but I fear its getting too coloured this way.
I want to add a "Passive" monitor control instead but still need another Analog out to do so. Now having so many Digital outs, I'm trying to think of best way to convert the SPdif out (for example) to Analog. One idea being a "Swisssonic Convertor"
https://www.thomann.de/ie/swissonic_con … _24_96.htm
I do use the Headphone Outs directly at the moment too, so I'm a bit stuck.
Is this a decent idea or are there better setups possible here in someway I have not thought off? (I guess I could but a better converter but not too expensive)
What do you do?
