Topic: Fireface 800. I can't use multiple standalone soft synths.
Hi
Win 7 ult 64 bit
Fireface 800
RME TotalMix FX 1.07
I can only use one standalone soft synth at a time.
If I open a standalone synth and assign a midi channel, it works fine.
When i try to load a second soft synth, I am unable to assign a midi channel to the second soft synth.
The 1st soft synth continues to work fine..
This only happened after a clean install. Before the clean install I was able to use multiple standalone soft synth with no problems.
Is there a setting that allows multiple soft synths? or can anyone suggest a solution.
I installed the latest driver.
Thank you
