Topic: UFX + Babyface Pro + Samplerate changes = problems
Hey guys,
I got two problems with my Babyface Pro connected via Toslink to the second ADAT port of my Fireface UFX. The clock source of my Babyface is set to "Optical In".
1) When I change the samplerate of my UFX from 44,1kHz to 96kHz, the Babyface stays at 44,1kHz. I have to manually change the samplerate, why is that? The only thing that changes is that the sample rate in the Babyface settings dialog is now in red, still stays at 44,1kHz and is followed by "Current: 48000 hz". The input status however says "ADAT Sync 96kHz"
2) The main output of the Babyface is also routed to ADAT1-2 because my monitors are connected to the Fireface. So everything that the Fireface receives on ADAT2 1-2 goes straight to its main out - works perfectly. Now when changing the samplerate to 96kHz, you only get 4 channels per ADAT input which is fine but it also changes the channels in Total Mix. ADAT2 1-2 is now on a different channel in total mix which kills the routing. Is there a way that the routing is preserved?
Thanks in advance!
Best,
Klaus
