Topic: MADIface USB with Soundcraft Compact Stagebox
Hi, New to this forum (and RME) so apologies if this comes across as a newbie question....
We have a MADIface USB connected to laptop which connects to a Soundcraft Compact Stagebox via optical which in turn is connected to a Soundcraft Vi1 via Cat5
As described in page 10 of :
https://3e7777c294b9bcaa5486-bc95634e60 … iginal.pdf
The laptop sees the madi channels of the RME interface and the desk sees the madi channels of the card fitted to the compact stage box - however, there is no data passing beteen the two. I have no 'signal' lights on the MADIface or the optical card Compact Stagebox. Thought is could be the optical cable but that worked on a different setup so assuming that's OK (not sure how to test it).
Anyone successfully have this setup working?
Thanks,
Dave
