floyd pepper wrote:ramses wrote:floyd pepper wrote:again im not getting the results wanted, totalmix is probably still too intelligent for me.
is there a simple way to Always have totalyser reading my (master) main out?
no matter daw input or line/mic input etc.
so always reading main (assigned main out AN 1/2).
Save Setup, Save Workspace, Workspace Quick Select
On Win7 I can even pin the most often opened setup when right clicking to the DigiCheck Window pinned to the taskbar
and get all my 5 Digicheck Windows as I want .. with same Window Position, Driver Selection, Playback Channel selection.
i wish that did it for me but no..
all i want is main channels out analyzation, shouldn't be that hard.
really bugged out by this
I am missing a detailed / understandable description about your procedure which finally fails for you.
I am using DigiCheck now since several releases and I had no problem so far, it does what it should
and I can open it with all required screens as once.
v5.91:
1- pin the DC program symbol to the taskbar for even easier use
2- open all the DC windows that you require (FILE -> New DC Window)
3- for each of the DC windows, which you opened, you need to press F3 for input device setup
- choose proper RME ASIO driver, device, channel (i.e. Analog1 for L, Analog2 for R), Source Playback
4- Save the setup to a folder of your choice, I choosed my documents folder and subfolders: RME/Digichcheck
5- When saving the setup take care that you save it as .dc3 file.
For strange reasons "filename.dcw" is preselected change it manually to "filename.dc3"
Otherwise you might overwrite your saved workspace settings, and store settings therein if boith have the same name.
6- Then save your Workspace to a "filename.dcw" file
7- Open the workspace
8- Now you can close all windows by rightclicking the DC Window in the taskbar comfortably ("close all windows")
9- Now you can pin and open your workspace selection by rightclicking DC icon in the taskbar again
And all windows open with the properly selected driver, device, channel and settings.
