Topic: 6.3mm TRS Jacks for FF400
I bought a used FF400 from an artist acquaintance, and discovered the 10 analog input and output jacks at the rear panel have all suffered some corrosion on the metal conductors inside, and making very poor contact. The unit is otherwise working fine. I have tried cleaning the corrosion with contact cleaner (DeoxIT) but the results are not satisfactory.
Since this FF400 is out of warranty, I would like to attempt to replace the 6.3mm TRS jacks myself. I have extensive soldering/de-soldering experience and proper equipment (Metcal temp-controlled iron, Hakko vacuum de-soldering gun, etc.)
Can RME sell me exact replacements for the TRS jacks, or provide me the part number? I will need 11 replacement jacks, to cover for 10 jacks at the rear and the front headphone jack. I am located in the USA.
Many thanks!
scan80269
