Topic: USB audio skipping with ADI-2 DAC on Windows 10
I have been trying to use an ADI-2 DAC with a Windows 10 Home system (version 1709, build 16299.402). USB audio cuts out fairly often (several times a minute). It cuts out more frequently with a higher CPU load, but also happens just when browsing in Chrome and playing music through Tidal.
The driver is Madiface 09653. I tried using the built-in Windows USB2 driver instead, and it does not work at all (the USB device errors out with "the device needs further installation", same as reported here: https://www.forum.rme-audio.de/viewtopic.php?id=27028).
All "audio enhancements" are turned off.
These audio drops do not occur with other DACs or other USB audio devices, only with the ADI-2 DAC, and only with Windows. The DAC works fine with iOS and macOS. The same Windows system plays audio fine through other DACs and other audio devices.
The drops occur when the DAC is connected to any USB port.
I tried increasing the buffer size to 2048 samples in the madiface settings. Dropouts still occur. I also tried switching between 44.1k and 48k sample rates, in case the playback application (Tidal) is sending an unexpected sample rate. Dropouts still occur.
There is another thread on this forum about this problem (link edited out because the forum software only allows one link per post), but I do not speak or read German, so cannot follow the full extent of its recommendations. Those parts I could read referred to problems relating to Nvidia drivers. The machine in question does indeed have an Nvidia GTX 970 GPU (latest drivers, 391.35). If this is an Nvidia problem however, it does not explain why every other audio device I use with the machine works fine.
I have rebooted the machine and tried reconnecting the device. I also uninstalled and reinstalled the madiface driver. I tried two different USB cables. Dropouts still occur.
Please let me know what other information I can provide to help you debug the Windows driver.
