Topic: Wrong Sample Rate after adding Ferrofish Pulse 16 to Fireface 802
I've added a Ferrofish Pulse 16 to my setup using ADAT. They are clocking over ADAT.
I also have a Pioneer DJ mixer plugged in to the AES digital in to the RME Fireface. I used this to record vinyl through the Pioneer mixer. Since adding the Ferrofish the recordings are slow, presumably recording at the wrong sample rate. The Audacity settings look OK.
The confusing thing is even if I turn the power off the Ferrofish I'm still having the same problem! Is there a way around this without unplugging the ADAT cables everytime I want to record from the Pioneer through AES?
Thanks, G.
