1 (edited by mertas 2018-11-28 17:01:56)
Topic: UDP problem with TotalMix remote
i am running on the mac macOs Sierra.
all setup, anyway error: No UDP data received at all. Please check firewall setting on host.
I do not have any firewall on mac.
Could you please navigate me, how to solve on mac and where?
Re: UDP problem with TotalMix remote
What is the other device? What are your network settings in these two devices?
ipad
and my network setting on both devices
https://www.dropbox.com/s/r4nlppwwabzq5 … 5.jpg?dl=0
https://www.dropbox.com/s/wbxpkvr3ecfxo … 1.jpg?dl=0
https://www.dropbox.com/s/w90yxu3nhxuyj … 9.jpg?dl=0
Pic 3 (29) makes no sense - you can not use the Remote app on the host. The iPad is configured correctly, it seems (as it finds your 802), but a screenshot from the TotalMix FX Remote Settings is missing.
what setting from totalMix FX do you require?
Options - Network Remote Settings.
solved, after uninstal remote from mac and setup totalFX network setting according to ipad.
thanks for great support
I too got the "No UDP data" warning, but my Fireface UCX still connected. HOWEVER, it cycled through "connected" and "offline"  every 5 seconds (upper right indicator on iPad's TM Remote). Thus, of course, the two interfaces only came into sync every 5 seconds. FYI my systems: MacBook Pro 15-inch 2017 touchbar, MacOS High Sierra; iPad mini v4, iOS 12.1—TM Remote 1.14, TM FX 1.50.
Obviously on the same WiFi network, but, in checking, I discovered that I had two network interfaces active (Ethernet AND WiFi, albeit different IPs). When I unplugged the ethernet cable my TM Remote became rock solid.
Hopefully this will help someone else troubleshoot a similar situation.
the same for me!
Not sure whether this is an old article, but it appears to me that you should set service order to Ethernet over WiFi.
https://discussions.apple.com/docs/DOC-11171
It makes no sense to use Wifi if Ethernet is also connected, then of course use Ethernet.
Was this issue ever solved? Because I am having he exact same problem with my Mac running Ventura and Totalmix Remote on my iPad.
I was having the issue on Mac OS Sonoma, I first turned off the ethernet that worked, but then I turned it on and did the reordering and that also worked, ethernet is ordered first and wifi second for me and still working, thanks!
