1 (edited by mertas 2018-11-28 17:01:56)
Topic: UDP problem with TotalMix remote
i am running on the mac macOs Sierra.
all setup, anyway error: No UDP data received at all. Please check firewall setting on host.
I do not have any firewall on mac.
Could you please navigate me, how to solve on mac and where?
Re: UDP problem with TotalMix remote
What is the other device? What are your network settings in these two devices?
ipad
and my network setting on both devices
https://www.dropbox.com/s/r4nlppwwabzq5 … 5.jpg?dl=0
https://www.dropbox.com/s/wbxpkvr3ecfxo … 1.jpg?dl=0
https://www.dropbox.com/s/w90yxu3nhxuyj … 9.jpg?dl=0
Pic 3 (29) makes no sense - you can not use the Remote app on the host. The iPad is configured correctly, it seems (as it finds your 802), but a screenshot from the TotalMix FX Remote Settings is missing.
what setting from totalMix FX do you require?
Options - Network Remote Settings.
solved, after uninstal remote from mac and setup totalFX network setting according to ipad.
thanks for great support
I too got the "No UDP data" warning, but my Fireface UCX still connected. HOWEVER, it cycled through "connected" and "offline"  every 5 seconds (upper right indicator on iPad's TM Remote). Thus, of course, the two interfaces only came into sync every 5 seconds. FYI my systems: MacBook Pro 15-inch 2017 touchbar, MacOS High Sierra; iPad mini v4, iOS 12.1—TM Remote 1.14, TM FX 1.50.
Obviously on the same WiFi network, but, in checking, I discovered that I had two network interfaces active (Ethernet AND WiFi, albeit different IPs). When I unplugged the ethernet cable my TM Remote became rock solid.
Hopefully this will help someone else troubleshoot a similar situation.
the same for me!
Not sure whether this is an old article, but it appears to me that you should set service order to Ethernet over WiFi.
https://discussions.apple.com/docs/DOC-11171
It makes no sense to use Wifi if Ethernet is also connected, then of course use Ethernet.
Was this issue ever solved? Because I am having he exact same problem with my Mac running Ventura and Totalmix Remote on my iPad.
I was having the issue on Mac OS Sonoma, I first turned off the ethernet that worked, but then I turned it on and did the reordering and that also worked, ethernet is ordered first and wifi second for me and still working, thanks!
I’m also having the issue of connecting and disconnecting every few seconds.
M1 Macbook Pro to 13”iPad Pro, latest OS on both. No ethernet involved. WiFi from a Huawei Mesh 3 router system.
I have limited experience here, but the comment I made above you with the link attached worked.
In my case, the host computer isn’t using Ethernet at all, so there’s no order to change. Thanks though.
Just for others, HMan opened a new Thread for this here:
https://forum.rme-audio.de/viewtopic.php?id=40664
“Do It For Her”
