Topic: Technical questions - ADI-2 DAC
Hi I have a few technical questions about the ADI-2 DAC, which I am almost ready to buy.
The ADI-2 DAC has 1x Balanced and 1x Unbalanced pre outputs. Can you use both at the same time, to power both a power amp (speakers) and a subwoofer?
I'd power the power amp by XLR and the sub by RCA, so the RCA would have less power at any time I'm assuming? I could correct this by increasing the sub volume. Or can I somehow match the voltage of the XLR and RCA outputs?
Can this unit actually supply enough power for this use - to my understanding it would need to supply 2.8V (1.4V for each of the amp and the sub; that is, line level)?
On the unit, how do you switch between headphone output and line output?
